Plastering Angle bead
Discussion in 'Builders' Talk' started by Blue0001, Apr 23, 2023.
  1. Blue0001
    Blue0001 New Member
    I’m plastering a media unit I’ve build, I’ve put angle bead on all corners of the recessed shelves I’ve put in but I normally finish work at 4 so I will be stretched for time. I’m hoping to get all the recessed shelves plastered before I do the face of the unit so is it possible to plaster up to the one side of angle bead and then at a different date plaster the other side in the face of the unit. Just looking to find out if this will cause any issues.
