My bathroom is fully fitted, floor to ceiling with glazed tiles. Is it possible to plaster over the tiles as I only want limted tiles aound new equipment? If it is possible, what special precautions or preliminary treatments are needed Thanks
As long as the tiles are on sound,no loose areas it can be done. Coat tiles day before skimming with either 'Thistle bond it' or PVA with kiln dried sand mixed in well. You might have to stick the beads on with some finish,then skim. No problem!!
> As long as the tiles are on sound,no loose areas it can be done. Coat tiles day before skimming with either 'Thistle bond it' or PVA with kiln dried sand mixed in well. You might have to stick the beads on with some finish,then skim. No problem!! .....:^O
