Plumbing a 1.5 sink. Hows it done???
Discussion in 'Plumbers' Talk' started by CosRush, Nov 4, 2008.
  1. CosRush
    CosRush New Member
    Ive tried a search or both descriptions and images and found nothing.
    Does each bowl have its own trap which then connect to a pipe section leading outside???
    or is it done another way. If anybody has any links to a picture that would help.
    Thanks in advance.
  2. sinewave
    sinewave Screwfix Select
  3. Bonedry
    Bonedry New Member
    Should come with a pack that has all relevant connections.
    If not you can buy a pack of connections from most merchants.
  4. CosRush
    CosRush New Member
    Thanks for the replies.
    Ive since found some pictures of a '1.5 bowl waste kit' and this has now cleared it up for me.
    The trap come after the 2x bowl are connected as opposed to individually.
    Thanks again.
  5. GKU
    GKU New Member
    :^O :^O - Bet ya feel a bit sussed asking the question now bud ;)
  6. Captain Leaky
    Captain Leaky New Member
    It's not the "right way" to plumb 11/2 bowls with two traps but it wouldn't hurt if you did. ;)
  7. CosRush
    CosRush New Member
    GKU,
    Dont follow what you mean 'sussed'???
  8. CosRush
    CosRush New Member
    Thanks leaky for the reply,
    My initial concern was that I didn't think i'd have enough room for a trap on the .5 bowl, but now having seen the 'waste kit' I see how its done, and that the .5 bowl connection is alot smaller than a trap would be.
  9. GKU
    GKU New Member
    "Don't follow what you mean 'sussed'???"
    embarrassed , bud , its a very basic plumbing job (if you are a plumber) :)
  10. sussexplumb1
    sussexplumb1 New Member
    If the waste kits a cheap one supplied with the sink then throw it away and buy a McAlpine 1.5 sink waste kit. The cheapo stuff will never ever fit you waste pipe.
  11. CosRush
    CosRush New Member
    Ah I see, no im not embarrassed at all.
    And im not a plumber.
    Not everyone is blessed with all knowledge before they have to learn it ;)
  12. CosRush
    CosRush New Member
    Thanks for the tip.
    The sink didn't come with a waste kit at all.
    Cheers :)
  13. GKU
    GKU New Member
    Apologies bud , did'nt mean to offend you , are you training then or a DIY'er . Agree with SussexPlumb1 , get a McAlpine kit from a Plumbers merchant , better than the carp that normally comes with sinks , good luck ;)
  14. CosRush
    CosRush New Member
    GKU,
    No worries. Im a DIY'er and I do this in my spare time (of which I have little).
    Will do a search for a McApline kit now.
    Cheers.
  15. CosRush
    CosRush New Member
    Can anybody enlighten me as to what the differences are between the Sk1 and the sk2 (ssk2??)
    Ive found compaines selling them but other than listing the fact they are McAlpine they dont detail the difference and the pictures are the same for both.
  16. CosRush
    CosRush New Member
    Not to worry, ive found the info on McAlpines own website. SSk2 (2 bowl) is what I need.
    Thanks again to all who replied.
