Plumbing in an American Style Fridge in another room...
Discussion in 'Plumbers' Talk' started by BoiledEggs, Sep 15, 2020 at 4:07 PM.
  1. BoiledEggs
    BoiledEggs New Member
    Hello (sorry wasn't sure if this or the Kitchen Fitters forum was the right one to post in)
    I am considering getting an American style fridge freezer with plumbed in ice making facility- however, my current fridge is sited in a sort of lean to/conservatory type room next to the kitchen - hope that makes sense as this is the only space available.
    I'm wondering if it is possible to route the water pipe that far away - the kitchen is about 10ft x 8ft
    I've attached a picture to hopefully explain what I mean !! Can you let me know if you think it is possible / difficult / impossible without loads of hassle etc :)
    [​IMG]
  2. BoiledEggs
  3. FraserD
    FraserD Member
    You can buy pipe to extend it.
    Though they normally come with a few metres.
    If you have a route for it I don't see why not.
  4. DIYDave.
    DIYDave. Screwfix Select
    If you think about it, your water supply probably enters the house from the front aspect of the building, then via a network of pipes, be they copper or plastic, then to all rooms of the house - be it heating or taps, showers, baths, etc
    So, water supply to this fridge can be literally run anywhere it’s needed. Mains cold supply so it’s pressurised so will have the momentum to get to where it’s needed
    How the pipe gets from A-B, may be the only tricky part
    Depends what’s in-between said A-B and if you want pipework hidden or it can be on show
    Usually terminated with a washing machine type stop tap so you can isolate water supply when your changing the filter
    Are you looking at doing this job yourself or calling in a plumber ?
    If the latter, discuss pipe runs with him/her so you have no suprises after the job
    Pipes can usually be hidden but may mean lifting floors, chopping out walls, etc
    That’s all fine but will clearly add to the cost of the job and level of ‘destruction’ required and subsequent making good
    But yes, sure seems more than possible :)
