Plywood under laminate?
Discussion in 'Carpenters' Talk' started by CNorris, Jun 20, 2021.
  1. CNorris
    CNorris New Member
    Hi,
    My floorboards aren't the best and creak a bit. Some have been cut to get access to pipes and cables and I don't think I'll stop them all creaking unless I replace every nail with a screw!
    So I've bought some 8mm thick laminate flooring and some 5mm fibre board underlay, but I'm thinking about putting plywood down first because if I screw it to the floorboards it might stop them squeaking.
    Is there anything wrong with doing that? (other than the cost)
    If not, what kind of plywood do I need and is 5.5mm thick enough?
    Thanks!
  2. Jord86
    Jord86 Screwfix Select
    Plywood is a waste of time, you need to screw the floorboards down tightly to eliminate the creaks.
  3. I-Man
    I-Man Screwfix Select
    Exactly what Jord said... need to deal with the actual issue, not cover it up
