Polishing a sink
Discussion in 'Screwfix' started by Lijong Tao, May 15, 2018.
  1. Lijong Tao
    Lijong Tao Member
    My sink and drainer is looking its age. I want to polish it back up. I have a DA polisher for the car and an electric drill.
    What bits can I buy from Screwfix that either fit the Das6Pro or the drill and what compound would you suggest to bring it back to life?
    Thanks Li
  2. KIAB
    KIAB Well-Known Member
    Would use a food safe metal polish, which is tastless,odour free.
    https://www.clean4less.co.uk/vitopan-food-safe-steel-clean-500ml.html
    https://colbrook.co.uk/Stainless-Steel-Food-Safe-Polish-480ml-Aerosol-
    And use a suitable pad for your Das6Pro, they do compound, polishing & finishing pads,think things like goblet polishing mop (from competitor),cabbage mop & others to use with drill will have limited uses,without using a flexible shaft, better having a rag & some elbow grease for the awkward area's.
    http://www.thepolishingshop.co.uk/acatalog/Flexi_Pads_Foam_Buffing_Pads.html
  3. Astramax
    Astramax Well-Known Member
    Might be best to use a limescale descaling solution first.
    KIAB likes this.
  4. KIAB
    Good point,we have limited details, shame OP hasn't posted a photo of sink,would make things easier.
  5. Lijong Tao
    Lijong Tao Member
    There's no limescale on it. It is just scratched and dull. Thank you all
  6. Wayners
    Wayners Active Member
    Paste.. You can sometimes see at pound shops. It's a clay they dig out ground. Works great and oven cleaners use it. Add a drop of water to thin if required. See here
    Astramax and KIAB like this.
  7. rogerk101
    rogerk101 Well-Known Member
    Toothpaste usually does quite a good job of restoring former glory.
  8. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    And do you all assume it's stainless steel?
  9. Lijong Tao
    Lijong Tao Member
    It is, yes. Thanks for all the help everyone.
  10. Astramax
    No, we know it, coz we are chancers!:D
