Hi, I am thinking of building a porch from timber. How hard can it be? I already have one side of the porch "built" as that's the side of my living room. The roof is already in place by those fancy things you put on the house with tiles etc. So all I need to do is make a timber frame. The bottom of the frame will have lots of bits of time running each way. Then I rest the floor on top of the bottom of the frame. Then I add windows and a door and that's it? Am I missing something? Thanks!
so basicaly you have a canopy over the door already and you going to frame under it and put a door in it?
Be careful. There's a terraced house for sale on rightmove that looks like it's had an apex shed built at the front door. It's been for sale a long while...
Thank you Goldwise, I hadn't thought of that. To both of you: I have attached an image and thinking about it, it's already pretty much there especially with the wall that sticks out from the house? It's 3 x 1m so would I even need a bricky? What would YOU do? Thanks so much!
Plus, do I need those "wiggly" bits - are they holding up the roof bit above it? Might be a stupid question so forgive me if is!
I presume your planning on going from the window to the block work. And putting a door where the block work is. If so measure it out. Cause if it exceeds 3 square metres im sure thats when you need planning permission
