Porch new windows - price
Discussion in 'Other Trades Talk' started by Muzungu, Jun 10, 2020.
  1. Muzungu
    Muzungu Screwfix Select
    I wasn't sure if there was any point as the porch is in the shade all day, never catches the sun and I have never opened the current openers, having said that the old wood windows have trickle vents. I may well be missing something and would be glad of being pointed in the right direction if I am.
  2. masterdiy
    masterdiy Screwfix Select
    In an enclosed area like that, I would in my opinion put vents in. (suppose they could be put in Pvc frames)?
    Otherwise you just might start getting damp/mould issues.
    The old saying, do it right first time, will save you in the long run.
    Muzungu likes this.
  3. Jord86
    Jord86 Screwfix Select
    To be honest with you it's a total scam, similar to the nonsense the electricians have to go through, though all window firms who fit day in day out will be registered, but the one man bands may not be, just phone the council and pay a fee and someone will come out for five minutes to check the rating and what have you.
    ElecCEng and Muzungu like this.
  4. Muzungu
    So the quotes come in from £850 to £1600. The lowest quote from a company that has their own manufacturing plant and the only ones that have given me a complete breakdown of costs in an email, biggish setup based a couple of miles from me but only work in the North East.
    Just thought it may be of interest.
  5. masterdiy
    Dont forget a vent somewhere in the windows. :)
  6. Astramax
    Astramax Super Member
    But ask for more, more, more than one quote. :oops:
  7. Muzungu
    Just noticed an error, the second window height should be the same as the first, they have it 500 mm shorter!
  8. Are all the prices to do the job properly?, which means replastering the reveals, fitting window boards and no bodger beads stuck on.
  9. Jitender
    Jitender Screwfix Select
    Upvc windows wont look right.
    Also if you go upvc they will be much thicker profiles so the glass area will be reduced.
    Are current windows fitted behind the stone wall or into the recess, not sure If I have explained this correct?
    The only wood I would look at using is acoya (see Mr Rustsy project)
    Mr Rusty likes this.
  10. Mr Rusty
    Mr Rusty Screwfix Select
    Thanks Jitender Yes, I agree - uPVC will look really clunky in those narrow openings. Find a local joiners shop and ask them to make up some windows to take DGU in Accoya. This modified timber is virtually 100% stable (so doesn't stress paint finishes) and the chemical treatment supposedly gives it a massive lifespan - it looks and machines like knot-free pine (although it is slightly brittle) but the timber is chemically modified. Cost wise it's about the same as oak, so not cheap but not crazy, and as most of a window is labour won't make much difference. https://www.accoya.com/uk/products/windows-doors/
    However, it will definitely cost you more than uPVC. Also, your windows are fixed behind the stone - whatever you do don't let them fix them inside the stone! - uPVC IMHO often looks awful, and I think has the potential to look really terrible if they did that!
    Jitender likes this.
  11. Muzungu
    Next door's UPVC for comparison. I am keeping my wood door though.
    Don't know why they put the vertical bar in as well as horizontal, looks odd to my mind in a window that small.
  12. Mr Rusty
    Muzungu likes this.
  13. masterdiy
    Well if it were me, I'd go along with the neighbours upvc type, but do away with the Vertical bars.
    And, don't forget a vent .... o_O
    Zero maintenance with UPVC. :)
    Muzungu likes this.
  14. Muzungu
  15. Jitender
    Had a door made up using sapele from Stairbox, the window sister company.
    For the astragal bars they were stuck on. They glass is basically one unit instead of lots made up, which would mean chunkier bars to support the weight.
    Go for same window sizes and spacings as they look good as they are.
  16. Jitender
  17. Frutbunn
    Frutbunn Active Member
    I note FENSA and building control were mentioned here, a porch is actually exempt from the provisions of Building Regulations.
  18. stevie22
    stevie22 Screwfix Select
    Glass and electricals have to comply
  19. Muzungu
    Just thought I would give the result. Estimates from £880 to £1600. I was a bit wary of the cheapest estimate as the nearest to it was £1200 so quite a bit cheaper, but I went with the cheapest anyway as they were a local firm with their own manufacturing plant. Pleased with the result. I went for the external glazing bars, not the ones internal to the glazing unit, and the guy has done a good job in my humble opinion, nice profile on them.
    gadget man, Jord86 and Mr Rusty like this.
  20. masterdiy
    Looks very nice and neat from here.
    Did you go for wood?
    I can't see a vent.....
