Position of earth bonding
Discussion in 'Electricians' Talk' started by Tony Pirie, Feb 14, 2020 at 5:25 PM.
  1. Tony Pirie
    Tony Pirie New Member
    I am wondering the position of the earth bonding clamps is it before the isolation valve on the gas and water or is it after thanks
  2. dobbie
    dobbie Well-Known Member
    After within 600mm and before any tee's/branches.
  3. spinlondon
    spinlondon Well-Known Member
    Not on the plastic supply pipes.
    Tony Pirie likes this.
  4. Bob Rathbone
    Between the gas meter outlet and the first tee or branch and within 600mm of the meter. For the water, if the pipework is metallic, directly above the incoming stop valve, if a water meter is fitted you must also bond across that. Do not fit a bonding clamp to a lead pipe or any other pipe that may be crushed as the clamp is tightened.
  5. peter palmer
    peter palmer Well-Known Member
    The regs only say 600mm where practical, its not set in stone. You wouldn't rip a brand new bathroom to pieces just to bond a water pipe if you could do it in the airing cupboard next to it 700mm away.
  6. dobbie
    The earth clip goes on the consumer side of the valve, not the supply side, and why would you try to strap an earth clip on a plastic pipe.
  7. Rulland
    Rulland Well-Known Member
    You would be surprised how many times I've seen it done by the have a go heroes :cool:
    dobbie likes this.
