Postcrete
Discussion in 'Landscaping and Outdoors' started by Jase81, Apr 9, 2022.
  1. Jase81
    Jase81 Member
    Intending to lay a layer of postcrete as foundation for sleeper retaining wall. Do I lay it, add the sleepers, Reba rod them in...then 'water' them (ie the base) to activate the cement?
  2. chillimonster
    chillimonster Screwfix Select
    don't think you'll have time do water first then get the sleepers in correct
    and start rebarring.
    I've never used postcrete as footings. How thick / deep are you planning the footing.
    It would be cheaper with sharp, 20 aggregate and cement.
    Jase81 likes this.
  3. AnotherTopJob
    AnotherTopJob Screwfix Select
    As said, Postcrete is completely unsuitable for what you propose. Go with a traditional concrete mix.
    pppmacca43 and Jase81 like this.
  4. Jase81
    Jase81 Member
    Great thanks both...will do!
