Potterton Performa 28
Discussion in 'Plumbers' Talk' started by tinytimbach, Sep 14, 2021.
  1. tinytimbach
    tinytimbach New Member
    A recent problem led to a visit from an engineer who found that a mouse had eaten a hole in the clear plastic pipe that goes from the gas valve to the burner. What is the purpose of this pipe?
  2. Muzungu
    Muzungu Screwfix Select
    Sounds like the pressure compensation pipe. This references the pressure in the combustion chamber, which will be slightly negative in respect to atmospheric, to the gas valve.
    My background is industrial so any domestic engineers please put me right but the theory would be the same I would have thought.
    tinytimbach likes this.
  3. pppmacca43
    pppmacca43 Super Member
    did the engineer fix it? I’m surprised he didn’t tell you what work was carried out and a basic description of what the parts were.
  4. tinytimbach
    So it is a secondary safety thing after the flame failure electrode? If the gas does not light the pressure does not drop and the gas valve switches off?
  5. tinytimbach
    Easily fixed except the engineer did not have any pipe but I had some in my workshop...
    pppmacca43 likes this.
  6. Muzungu
    It is my understanding, I am not a domestic engineer, that the compensation pipe to the valve is more to do with precise gas flow regulation though will also shut of the gas if there is a flue blockage when the combustion chamber pressure increases to above atmospheric, i.e. above that at the valve.
    Just to repeat again, I am not a domestic engineer, I am using my industrial knowledge which may not be directly transferable to domestic. I am very wary of giving any advice in a domestic situation so welcome confirmation of this from a Gas Safe engineer.
