Power in loft for CCTV NVR etc
Discussion in 'Electricians' Talk' started by Seelda, Dec 25, 2020.
  1. Bazza-spark
    Bazza-spark Screwfix Select
    Ha ha, you don't know and can't tell us. Waffling again!
    Have a look at 524.
  2. Bazza
    Bazza Screwfix Select
    I wasn’t being exactly truthful, you know!
  3. Bazza-spark
    Didnt think so. Just wanted Banal :p to see I did know :D
  4. Arthur Dent
    Arthur Dent Member
    If we deleted the 'B' surely that would be more appropriate.
    Bazza-spark likes this.
  5. Bazza-spark
    Yes, but he would report me again and get me banned again.
    He can post inaccurate dangerous info, but I get banned for name calling.
  6. Banallsheds
    Banallsheds Well-Known Member
    Anyone can. I don’t.
  7. Bazza-spark
    I have pointed the issues out to you, bit as ever you are in denial.
    You still have answered the question and I gave you a clue.
  8. spinlondon
    spinlondon Screwfix Select
    I did report one of BAS’s post for being dangerous advice quite recently.
    Can’t remember which, I think it was the one where he said an FCU wasn’t required to spur off a RFC to feed a boiler.
  9. simbad
    simbad Member
    just a thought, do you have a shower ring circuit in the loft? maybe use that? When in the shower just turn the cctv off and shower on, vice/versa? unbelievably when we brought this house i went in the loft for whatever reason and happened to notice that the shower circuit went to the shower, bathroom lights, heater fan and extractor! apparently the t**t was an electrician!
  10. Teki
    Teki Screwfix Select
    Electric showers are generally on a circuit of their own. CCTV is usually meant to be on 24/7 and with the low current draw, it could be left on all the time on a shower circuit.
    If the circuit for your shower etc. is appropriately rated, there is nothing wrong with running the other items you mentioned. Not conventionally done that way as you'd normally have the lighting and extractor on the lighting radial.
  11. Banallsheds
    I never said that.
  12. spinlondon
    I’m afraid that you did:
  13. Banallsheds
    A FCU is obviously not required if is is feeding a socket as the plug has a fuse.
  14. spinlondon
    It is required when it’s feeding a socket and a boiler.
  15. Teki
    I wonder if @Seelda decided it wasn't worth all the hassle to install the CCTV/NVR and lights! :rolleyes:
  16. Banallsheds
    Not if the boiler is plugged into the socket.
  17. Bazza
    @Beni_Alb is that you advertising your product?
