Power supply to greenhouse
Discussion in 'Electricians' Talk' started by starbuild, Feb 12, 2004.
  1. starbuild
    starbuild New Member
    I need to supply power to my greenhouse which is about 30 yards down the garden. What are the pros and cons of burying 25 mm MDPE blue pipe about a foot deep below my lawn to carry 2.5 mm T and E from its own fuse in the CU?
  2. RES
    RES New Member
    A foot sounds a bit shallow, you should be going for 500mm or 1 foot 8 inches at a minimum. Obviously avoiding anywhere likely to be dug up during gardening.
    The cable should really be armoured, and the armour wires made off to earth in case a spade etc pierces the cable.
  3. ADSL Nation
    ADSL Nation New Member
    Use proper SWA it's not expensive, under £1 per m from an electrical wholesaler.
  4. limestone cowboy
    limestone cowboy New Member
    I'd use armoured. It will be difficult to feed the T&E down the MDPE and there's always the risk that it will get mistaken for a water pipe. Also cables are supposed to be black or in black ducts. The cable should be about 450mm deep on private property and under footpaths. I would put marker tape 150mm above the cable.
