Preparing peeling emulsion walls for wallpaper
Discussion in 'Painters' Talk' started by Lydiapenny, Mar 25, 2018.
  1. Lydiapenny
    Lydiapenny New Member
    hi
    we have emulsion walls that are peeling and we want to wallpaper them, what is the best way to treat them before we wallpaper to stop the paper from coming away
  2. Will Roberts
    Will Roberts New Member
    I had a similar issue but with painting the walls. I used a primer paint then PAINTED over that... I can't see why I shouldn't be any different for wallpaper Good luck though
  3. Dr Decorator
    Dr Decorator Active Member
    From a previous job I did, scrape of as much of the peeling paint as possible, sand then give a coat of Zinsser Peel Stop
    Will Roberts and Astramax like this.
  4. DIYDave.
    DIYDave. Well-Known Member
    The above may well work but depends how many layers of emuslion has been lashed over the wall and what type of paper ur going with
    When you remove areas of peeling paint, the edge around the firm paint may well show through the wallpaper once dried
    Probably won’t see it when first putting up the paper but as it dries, it shrinks slightly and tightens up
    If there’s noticeable edges to the paint, the paper may shrink back into these patches and look horrendous
    Depends to a degree on type of paper ur considering. Very thin paper I wouldn’t risk it, even light weight lining paper, say 800 grade may show up paint edges
    If your using an embossed paper then not an issue, or consider lining paper, minimum 1400 grade
    All depends though on condition of wall. Where the paint is peeling, is it going back to plaster or further layers of paint ?
