The plasterboard studded walls in our house was wallpapered by the previous occupant. We are in the process of removing the wallpaper because we want to go with painted walls and plan to have them re-skimmed as we are aiming for a quality finish. We have discovered a patchy layer of emulsion paint underneath the wallpaper. This emulsion paint comes off quite easily with steam and a Harris scraper. Should we take the time to remove all this as well so that the new plaster can be applied directly onto the original plaster or will a professional plasterer say this extra work was unnecessary?
If the walls are in a fairly good condition why not prepare and line walls with a good quality 1200 grade lining paper, lot less mess and agro.
... because we don't want to see any lines - just lovely smooth painted walls But, your response is very much appreciated
Who is this person who skims lining paper? .....................Emulsion paint on top of the lining paper.
thought so... (just checking)... LOL but surely, the joins will be visible albeit maybe only if you look close?
If emulsion is sound leave. If it's not then remove if it comes off easy. If I skim naff surfaces I chip and scratch up surface back to good for a good key for plastering, then seal ready to skim.
2 weeks ago I repainted 2 rooms and a stairwell that I lined 7 years ago, a new fireplace had been fitted so part relining on one wall was required, had a job to find the joins before and after redecorating.
Thanks Wayners, you'll be pleased to hear that my wife concurs with you! Just gotta get her 'Harris Scraper' trained now LOL
Yeah. Leave to the whoever is going to plaster to prep it. Should talk through what needs doing when quoting. I use a wood saw blade and drag across lines to get a good key. Other ways of doing it though.
