Pressure Drop
Discussion in 'Plumbers' Talk' started by flyingscotsman, Apr 30, 2010.
  1. flyingscotsman
    flyingscotsman New Member
    Hi guys, bear with me, as I am but a humble carpenter. I have just installed mixer taps on my bath using flexi connections, the pressure now is less than that of the sink. Any ideas as to what would cause this. :(
  2. antaclue
    antaclue New Member
    Well, high pressure taps on low pressure pipework, i.e. tank fed, skinny/kinked/squashed flexi`s, pipe blockage, probably the first one, this is why you pay your money to decent plumbers and not DIY
  3. flyingscotsman
    By "skinny" anta, do you mean a smaller inside diameter on the flexis. The pressure on the nearby sink is quite strong, on 15mm pipe, fed from the same tank.
  4. rome60
    rome60 New Member
    There will be more resistance on the basin taps compared to the bath mixer,making the flow rate higher.
  5. flyingscotsman
    Apparently the flow rate was fine before the new taps/connectors went in. I was just wondering if the pushfit connectors had something to do with it.
  6. Doneitwrongagaindad
    Doneitwrongagaindad New Member
    If you do the following the flow rate will increase:-
    Replace isolators with "full bore" 22mm isolators.
    Throw the flexis away (reduce flow rate substantially).
    Fit 22mm all the way to the tap connector (copper - or if you have to - plastic).
    Hope this helps.
  7. tackleburger
    tackleburger New Member
    Won't make any difference if the taps need a bar of pressure though. Check the book that came with the taps for every 0.1 bar the taps require you need a meter of height to the tank. So if the taps require 0.5 bar minimum to work at optimum level your tank needs to be 5 meters higher than the tap! Got it?
