Prime smooth shiny MDF
Discussion in 'Painters' Talk' started by fred812, May 18, 2021.
  1. fred812
    fred812 Active Member
    The smooth shiny surface of MDF sheet I mean. Its going go be used as shelves and emulsioned, can I just water the first coat down a bit for the primer? It's Dulux Trade Matt.
  2. Wayners
    Wayners Screwfix Select
    Acrylic primer then eggshell or durable emulsion will take the day to day use vs emulsion.
    Although you can just use emulsion but not really the right thing
  3. koolpc
    koolpc Screwfix Select
  4. fred812
    Thanks both,
    What's durable emulsion?
    I've got some Bullseye 123, will that be ok?
    Never quite understood the difference usage of Bin vs 123
  5. I-Man
    I-Man Screwfix Select
    Bullseye will work fine
    koolpc likes this.
  6. koolpc
    123 is water based, quick drying, less odour i believe.
