Priming MDF
Discussion in 'Painters' Talk' started by RolandK, Sep 6, 2018.
  1. RolandK
    RolandK Active Member
    I need to paint some MDF but using such as acrylic primer/undercoat or any thing water based in the past has always raised the fibres leaving a surface which needs a load of work. Can I use a solvent based primer/undercoat then water based topcoat? Or any other advice welcomed!
    Cheers
  2. diy_nixy
    diy_nixy Active Member
    You can still use water based primer and paint. You just need to sand down between the coats.
    I wont explain the whole procedure because GosForth Handyman on Youtube has done a great video.
  3. DIYDave.
    DIYDave. Well-Known Member
    Yep priming/painting cut edges of MDF does take a bit more work to get a good finish, agreed
    I always use Leyland Acrylic Primer Undercoat, over all surfaces of MDF, never bother with a specific MDF primer, 2 coats on the smooth faces gives a great base to then paint on. Light rub down inbetween all coats, P120/180
    1st coat will raise the fibres and give a rough finish, sand down and prime again. I use 4” foam roller and with a dry brush, remove overspill from faces. 2nd coat will need less rubbing down, just very quick rub over. 3rd coat of primer, repeat
    Sounds drawn out but this stuff dries in an hour max and as it has plenty of ‘body’, it also acts almost like a filller, smoothing out the cut surface
    3 coats of primer and sanding should leave you with a surface as smooth as the face. Depends how neat the cuts are in the first place though ?
    KIAB likes this.
  4. KIAB
    KIAB Well-Known Member
  5. RolandK
    Thanks for the info. Perhaps the MDF I've used is not so good but on one window sill it was still raising the fibres after 3 coats of primer! I'll persevere though and try the Leyland primer. I don't ever bother with trying to paint cut edges, I use iron on wood edging and get round it that way.
    Cheers
  6. WillyEckerslike
    That's a good point. Some of the MDF sold in the sheds can be difficult to get a good finish on the edges. Definitely variable quality MDF around. I believe that Medite (trade name) or water resistant MDF is of better quality when cut.
  7. RolandK
    The MDF is from Wickes and looking at the surface the wood fibres are quite visible. I'll make sure I take a better look in future. As I said I tend to edge cut edges but in this case the surface is the problem. Or perhaps I'm just too fussy as my other half is always telling me!
  8. Astramax
    Astramax Well-Known Member
    Have you chaps never heard of Cellulose Sanding Sealer!
    Paulie1412 likes this.
  9. RolandK
    Tell us more......
  10. DIY womble
    DIY womble Well-Known Member
    Out of curiosity has anyone tried a heat gun on cut edges before priming
  11. Jord86
    Jord86 Well-Known Member
    PVA and water 50/50 also works, sanding between coats.
  12. chippie244
    chippie244 Well-Known Member
    Shellac
  13. DIY womble
    Heat gun
  14. RolandK
    That surprises me on two counts. First wetting it with that amount of water and secondly using the deadly PVA under paint!
  15. RolandK
    That's the sort of thing I was thinking of. Something non water based to seal it before the water based stuff goes on. Going to look up the cellulose sanding sealer Astramax referred to as well.
    Cheers
  16. chippie244
    Shellac followed by very fine wet and dry works every time and gives an excellent surface, I've also used Leyland acrylic primer and had good results, I've never tried PVA or a heat gun.
    DIYDave. likes this.
  17. RolandK
    Oh yeah having looked it up it was the stuff I used on my balsa planes many moons ago. Forgot all about it!
  18. Astramax
  19. Astramax
    Used gallons of Shellac Sanding sealer when Antique pine furniture was the flavour, applies and left overnight to fully dry hard whereas Cellulose Sanding Sealer is dry in a matter of minutes.
  20. chippie244
    I don't know what you were using but it dries very quickly.
