Priming new plaster for painting
Discussion in 'Painters' Talk' started by Danny Morton, Oct 20, 2021.
  1. Danny Morton
    Danny Morton New Member
    Hi there,
    Just got a lot of work done and have lots of new plaster to paint. My dad recommended using watered down wall paper paste to prime plaster for paint, is this a recommended way to prime new plaster for painting??
  2. Dr Decorator
    Dr Decorator Active Member
    Gardz or Drywall Pro
  3. I-Man
    I-Man Screwfix Select
    Contract matt watered down 50/50...just check instructions on the bucket
    pppmacca43 likes this.
  4. Wayners
    Wayners Screwfix Select
    Acrylic Primer undercoat if topping off with vinyl matt or durable
    Ask 10 people get 10 different answers.
    Some paints including durable types in trade range recommend using the emulsion thinned while others recommended acrylic primer. So depends what your using as top coat
  5. Bob256
    Bob256 Member
    Probably a thinned down coat of whatever you are using would be sufficient. Look at what it recommends.
    However, definitely not wallpaper paste or PVA or anything like that as it will make painting a nightmare. Many years ago I took the advice of someone telling me to seal plaster with watered down PVA before painting. Never made that mistake again!
  6. pppmacca43
    pppmacca43 Super Member
    Just use a watered down paint for the first coat as I-man says.
    no need to reinvent the wheel for something so simple.
