Priming subfloor
Discussion in 'Tilers' Talk' started by kevino, Jul 12, 2018.
  1. kevino
    kevino Member
    hello all,
    I’ve got 18mm osb subfloor,
    I’d just like to know if you prime this before sticking down cement board with adhesive?
    Thanks
  2. CGN
    CGN Well-Known Member
    I would.
  3. kevino
    kevino Member
    Thanks for your quick response CGN
    CGN likes this.
  4. rogerk101
    rogerk101 Well-Known Member
    I would also screw it.
    The intense heat and drought of the last couple of months have caused so much shrinkage in my subfloor that I'm now hearing movement when I walk on my bathroom floor that has a similar make-up to yours. This floor has never done this before and it has been down for nearly 9 years. I'm just hoping it returns to being no-noise when the rains start again, but I doubt it.
  5. kevino
    kevino Member
    Thanks , yes I was going to screw as well , hopefully I can find the appropriate screw as I’ve seen the specific screw is too long for my 18mm board + 6mm backer board
  6. rogerk101
    If it were mine, I'd try to screw into the joists ... after checking that there were no pipes or wires to pierce.
  7. kevino
    kevino Member
    Good advice, I will do that too
    Thanks
