Problem cutting long shims (angles) on a Table saw
Discussion in 'Carpenters' Talk' started by Slipsurfer, Oct 10, 2006.
  1. Slipsurfer
    Slipsurfer New Member
    Trying to cut long shims (wedges) on a Rexon 12" Table saw for creating the fall on a wet room floor. Built a taper jig as per Norm on NYW, but kept getting burn and the blade jamming. Any advice please ?
    Could it be that my blade is dull?
    Cheers
    Slipsurfer
  2. dirtydeeds
    dirtydeeds New Member
    there are generally two reasons for burning wood, one you have already guessed (a dull blade) secondly too slow a feed rate
    no joke, you can get timber to burst into flames
    i havent seen New Yankee Workshop but am aware that it will be some sort of "sled" that is being used
    a lesser known reason for burning wood (which is realy a variation on the first two) is using a crosscut saw for ripping, but essentially it is still a rate of feed question.
  3. jasonb
    jasonb New Member
    Either a blunt blade or too many teeth, for ripping you don't want much more than 24 teeth. Also make sure the timber is not moving away from your taper jig and that your riving knife is the correct thickness for your blade, I assume you are using the riving knife/crown gaurd unlke Norm!!
    Jason
  4. bodget&scarpers
    bodget&scarpers New Member
    y not just use square stock and wedge/pack it up 4 the fall.when the sub board is fitted it wont move.
  5. Caveman
    Caveman New Member
    Slightly glib answer - if your shims are less than 8ft, then instead of cutting down timber lengths, get yourself a sheet of plywood, mark up your wedges on the sheet - easy way is to mark up strips+twice the width of the saw blade and then the diagonal of the strip (I hope that makes sense!). No need for any fancy jigs. If you have problems following the lines, add a bit then plane down to the line. If necessary, use two wedges per joist. It worked for me!!
  6. gadgetgeek
    gadgetgeek New Member
    Hi - I suggest you forget the table saw and get yourself a Festool TS55EBQ complete with guide rail. It'll do this job and a million others... neater, quicker and much more portable than any table saw. Check out the www for info.
  7. Slipsurfer
    All sorted....
    Went back to basics, used a bench hook and a circlura saw with a laser.
    Fantastic results no need to plane shims.
    Thanks for all your help
  8. dirtydeeds
    a sideways take on your solution slipsurfer
    i use a bench hook used for cross cutting :)
