Problem with gutter
Discussion in 'Plumbers' Talk' started by sunnyard5666, Jun 7, 2018.
  1. sunnyard5666
    sunnyard5666 New Member
    Not sure if this is the right forum section but here goes. i had my bathroom moved upstairs recently and as a result the soil pipe was moved beside the guttering meaning the gutter had to be cut at the end and is now not flush with the wall and as a result when it rains, water come dropping down the wall and is starting to discolour it. Is there a remedy for this? Thanks in advance.
  2. KIAB
    KIAB Well-Known Member
    Why cut guttering,why wasn't offset bends used on soil pipe to step out around gutter?
    Got a photo.
  3. rogerk101
    rogerk101 Well-Known Member
    Or else why not just pop an air admittance valve on top of the soil pipe well below the gutter? You'd need to get one that's good for outdoor use, but it'd be a whole lot easier than messing with gutters.
    KIAB likes this.
  4. KIAB
    FloPlast AX110 is a external AAV, available in black & grey from our host.:)
  5. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    Simplest way now is to get a sheet of lead, fashion it from under the tiles, around the pipe(upstanding hole and slip it over top) and into gutter. Seal the hole/pipe union.
