Product to form a level surface on concrete slab
Discussion in 'Landscaping and Outdoors' started by Christopher Wright, Apr 20, 2021.
Tags:
  1. Christopher Wright
    Christopher Wright New Member
    Hi all,
    I have a concrete slab that I plan to use as a base for a tile footpath leading to my front door. The slab is laid to falls to allow water to drain away from the building but it is a little bumpy so before I lay the tiles I would like to use a screed or mortar style product to smooth over the surface.
    Please can you advise on what type of product I should use to smooth over the surface, I have seen lots of various types and can’t quite figure out which is best. I know that there are levelling screeds but my thought is that they are maybe a bit to liquid and better for creating a dead level surface rather than smoothing a surface laid to falls?
    any advice will be greatly appreciated !
