Progress on roof leak
Discussion in 'Builders' Talk' started by Simba_ali, Jun 30, 2020.
  1. Simba_ali
    Simba_ali Member
    Ive been having issues with a leaking balcony roof onto a ceiling below which ppl in this forum have kindly helped offer advice.
    I've managed to make the leak occur by pouring water directly onto this roof upstand where the joint meets the brickwork. There is also movement when I press it.
    What's the best way to fix this as people have told me if doesn't look right and second how do i emergency repair it until I can get someone out? At the moment I've got duct tape over the joint (it's all I had)
    I've attached a photo
    Regards
  2. Abrickie
    Abrickie Super Member
    Lead flashing over upstanding :)
  3. Simba_ali
    Simba_ali Member
    Would running a thin bead of sealant over the joint help until I can organise this?
