pump constantly turning on
Discussion in 'Plumbers' Talk' started by sussexplumb1, Apr 20, 2010.
  1. sussexplumb1
    sussexplumb1 New Member
    Customer has one sided pump for hot water to whole house keeps turning itself on for a few seconds, will even turn on if a taps dripping. The set up is really bad it is fed from a combi tank think its caused by air getting into pump???? Could it be an over sensitive flow switch???
  2. G Brown.
    G Brown. New Member
    Onetap will be along shorlty to give advice on pump issues.
    Onetap?.
  3. G Brown.
    G Brown. New Member
    Onetap?
  4. doing a bit
    doing a bit New Member
    had this before , was backwashing, salamander pump, they said fit a low pressure non return on the pump outlet, worked too!
  5. G Brown.
    G Brown. New Member
    OH DAB you spoiled Onetap's day.
  6. doing a bit
