My pump pliers make me angry every time I use them. Because I’ve only occasionally used them until recently I hadn’t realised how terrible they actually are. I’ve still got a fair bit of plumbing work to do and wanted to get a pair that don’t slip every time I squeeze the handles. I’m not in the trade but I want a pair that will last and I’d actually enjoy using. Any suggestions?
Use these Bacho ones, have had a couple of pairs of them for years. https://www.screwfix.com/p/bahco-slip-joint-pliers-10-254mm/39865 Try tool station though, they are more than a fiver cheaper there.
What do you use your pump pliers on? Really only for rough work - like removing an old fitting that needs replaced, etc. I have 10” Lucas Elliott pump pliers very similar to Rothenberger type and just for smallish diameter work. Also take a look at Footprint wrenches. British made and very versatile. Can be bought in 6”, 7”, 9” etc and can be thumbwheel adjustment or removable bolt for different holes to adjust.
Pump pliers arejust that,maybe consider channel lock pliers (parallel jaw type) there american This 300mm version has offered excellent use for nearly 20 years,yes there surface rusty but thats something to do with the job
Love my pump pliers. (Rothenberger) But hate when using someone else’s. They just don’t feel or work the same.
I use Bahco slip joint and they feel good in my hand. Also, have a look at https://www.screwfix.com/p/rothenberger-spk-water-pump-pliers-10/83621 on clearance. If you can get hold of both, see which is most comfortable.
I use American Ridgid ones. They're really well made. There's a few types, but have a search on Amazon.
