Pushfit connection to washing machine
Discussion in 'Plumbers' Talk' started by mbrijun, Jun 29, 2020.
  1. mbrijun
    mbrijun Member
    Hi, I am looking for some advice on how to best connect a pushfit system to a washing machine. A PEX pipe is flexible and even with talon grips screwed down to the wall it bends under the weight of the washing machine hose. From what I read, side loads are a "no no" to pushfit connectors, so even a copper pipe would not help much. I could not find a 3/4 BSP pushfit wallplate, that would be ideal in this case.
  2. Jimbo
    Jimbo Screwfix Select
    Bit of 15mm copper into washing machine valve (which incorporate a non return valve btw) clipped to wall with two clips, and a push-fit coupler with appropriate insert to connect back to the plastic.
  3. mbrijun
    mbrijun Member
    While experimenting I came to the same conclusion as you that the last bit of pipe before the WM must be copper.
    In your advice, did you have a compression or a speedfit valve in mind? I ended up fitting a compression fitting, which seems to be much more tolerant to side loads (the weight of the WM hose in this case).
  4. Jimbo
    I always go for compression personally. Copper olive and a turn of PTFE around the olive always works for me.
  5. FraserD
    FraserD Member
    Isn't tape around an olive not only unnecessary but can also stop the olive compressing correctly?
    Not a criticism, just a question.
  6. Jimbo
    I've never had a problem, I tried paste but never get on with it. TBH the brass olives are really soft so it's easy to over tighten them into a squashed mess.
  7. FraserD
    FraserD Member
    Thanks, never used paste or tape.
  8. PTFE tape on a compression fitting is a bodge and also looks a bodge, if anything is to be used a smear of paste is all that is required.
  9. Jimbo
    One paste I do quite like is LS-X
