Pushfit gas?
Discussion in 'Plumbers' Talk' started by bathroom boy, Oct 20, 2009.
  1. bathroom boy
    bathroom boy New Member
    I fairly sure pushfit joints arn't allowed on gas, therefore, I rest my case in that they are not as reliable and trusted as soldered copper.
  2. HOTDOG ø
    HOTDOG ø Active Member
    What a Luddite you are!
    Don't you know anything about plumbing?
    Millions of miles of plastic plumbing is used today. All underfloor heating is in plastic as copper is unsuitable!
    Speedfit is not only used for plumbing - it is used in aircraft, submarines and automobiles for fuel lines etc.!
    Of course copper is good too and soldered joints are excellent but NOTHING is foolproof and ALL joints have the potential to fail.
    But prattling on about "inferior plastic" only serves to make you look a bit dim.
  3. audi-evo
    audi-evo Active Member
    I think they are brill........... it means a plumbing nupty like me can do bits of odd jobs that plumbers won't turn out for :)
  4. audi-evo
    nupties are not quite as bad as numpties btw ;)
  5. sinewave
    sinewave Screwfix Select
    All of Transco's UK Gas network has been plastic for 20 odd years now!
  6. musky1
    musky1 New Member
    Thats because it wont catch fire 18inches underground,you cannot use on gas,end of.They use electro fusion,mixed with a little reggie :^O :^O
  7. G Brown
    G Brown New Member
    Remember in some countries you can't even use copper for gas ! it has to be iron:D
  8. fetch&carry
    fetch&carry New Member
    I pass a lot of gas every day, probably due to all that bending down and I can assure you there isn't an inch of copper in my system apart from a bit of loose change in the jeans.
  9. hallbeck
    hallbeck New Member
    Using the same flawed logic.
    Soldered fitting aren,t allowed on oil pipes - so they must be unreliable.
  10. G Brown
    G Brown New Member
    And drain pipes are not made of copper so that must be rubbish too!
    I bet BB feels a bit of a * now!
    [Edited by: admin]
  11. doing a bit
    doing a bit New Member
    you cant use pushfit on gas because it would melt in the event of a fire, anything above ground is usually in screwed iron pipe to the meter etc
  12. HOTDOG ø
    I bet BB feels a bit of a * now! erm...not a star!
  13. bathroom boy
    Na I don't give a monkey, use quite a bit of speedfit where it can't be seen,ugly stuff, but theres none in my house. lol
  14. Crowsfoot
    Crowsfoot Screwfix Select
    I'm old enough to remember the old lead gas pipes and joining onto them with copper.
    It was much thinner than lead water piping and much easier to joint because you only needed to wipe a flange joint.
    However,even back in those days there used to be some controversy between plumbers as to wether or not you could flange copper straight in or to use a brass fitting between the lead and copper.
    That fitting was called a 4u.
    Ah, the olden days!
    You know I'm beginning to sound like my old grandfather :)
    Tappy,
  15. musky1
    musky1 New Member
    And as far as I know Tapnuts,youre still allowed to wipe a flange lead joint to a gas copper pipe,not that half the numbnuts on here could do one? ;)
  16. rp12345
    rp12345 New Member
    Why's that then ?
  17. Drax
    Drax New Member
    Because the kerosene may cause the the solder to decompose - Alledgedly
  18. Drax
    Drax New Member
    It would also fail in a fire.
  19. natrosol
    natrosol New Member
    Spot on DAB
  20. Water Systems
    Water Systems New Member
    flange joint.
    Ah, the olden days!
    grandfather :)
    Tappy,
    It was a cup joint and it was never wiped. The solder was touched on using a low heat blowtorch. It was a 4U union joint - 4U was the Gas Boards number for the union fitting. It was for disconnection only. Copper could easily be soldered directly into the lead. The Gas Board wanted a disconnection point.
