PVA before screed
Discussion in 'Builders' Talk' started by Kerry5455, Aug 1, 2018.
  1. Kerry5455
    Kerry5455 New Member
    I’m currently doing an extension up on my house & im doing the majority of the work myself.
    I’m about ready for the screed to go down - there are a lot of different opinions about this.
    Do I need to PVA the floor first? Is this worth while doing or do I just crack on with the screeding?
    Thanks
  2. Jord86
    Jord86 Screwfix Select
    No PVA. SBR instead.
    KIAB, Kerry5455 and masterdiy like this.
  3. DIY womble
    DIY womble Well-Known Member
    I'm sure SBR is great , in the old days we would wet the floor up with a cement slurry never had a problem, go for SBR , but just saying for chat
  4. CGN
    CGN Screwfix Select
    Be careful in this weather that it doesn't dry out too quickly and crack. Put some poly sheet over it.
    DIY womble and Kerry5455 like this.
  5. KIAB
    KIAB Super Member
  6. DIY womble
    SBR ebay £12.90 , 2 day delivery
  7. KIAB
    KIAB Super Member
    Kerry5455 likes this.
  8. Kerry5455
    Does the PVA / SBR still have to go down before a latex levelling?
  9. Jord86
    Yes, it aids adhesion and bonding strength.
  10. Kerry5455
    Thank you
  11. 14th edition
    14th edition Well-Known Member
    Just used SBR prior to floor levelling compound in our extension and one or the other [or both] has made the place stink like blocked drains!!
