Pva before self levelling compound ?
Discussion in 'Other Trades Talk' started by dvddvd, Dec 2, 2018.
  1. dvddvd
    dvddvd Well-Known Member
    im going to put some glue down Karndean flooring in a small hallway.
    I've used it before but only on plywood, this time it's on concrete.
    What the normal procedure?
    I have a tub of Karndean skim coat which I assume is their self levelling compound?
    Is it best to clean floor, then pva with a diluted? Mix?
    Then mix skim coat and trowel on?
    There are a few deep holes that have broken down near door, is it best to put a little concrete repair in these before skimming? I think the Karndean skim coat is up to 3mm?
    Thanks
  2. CGN
    CGN Well-Known Member
    SBR
  3. dvddvd
    What ratio do you thin SBR to seal before self levelling compound?
  4. CGN
    1:4
