PVC Damage
Discussion in 'Plumbers' Talk' started by Rebecca Price, Jul 31, 2019.
  1. Rebecca Price
    Rebecca Price New Member
    I have had a builder put in a pvc wet room for me. The plumber has damaged a panel in the shower area small hole in one underneath the shower near the shower tray can it be fixed or dose it have to be replaced advise please Thank you
  2. spirits are real 2016
    spirits are real 2016 Screwfix Select
    can you post pictures up please so we can advise better.
  3. DIYDave.
    DIYDave. Screwfix Select
    Guess (without pictures and more info) it could more than likely be sealed with a colour matched silicone but depends on what style of panel, how visible, size of hole, how neat is the hole and, if your prepared for a bodge fix to be carried out
    What has been discussed so far between yourself and plumber
    Unpleasant situation for all, let’s hope it’s rectified in a gentlemanly fashion as sometimes, s*it happens :)
  4. Rebecca Price
    This is the damage that has been done. You can put your finger through the hole. 20190731_092836.jpg
  5. DIYDave.
    Doesn’t look good at all, not sure if someone on here can suggest a fix using coloured resin and witchcraft but, it’s always gonna show I recon
    There are companies that repair chips and damage to bath surfaces so may be one avenue to explore .... but it’s only a guess
    Did the plumber make you aware of the damage in the first instance and what has he suggested as a way forward ?
    Would make sense for the plumber to also discuss this with the builder who did the install and see what the builder recommends, also get an idea of costs involved (for the plumber to swallow)
  6. Rebecca Price
    No found it myself so wonted some advise before contacting him
  7. Pollowick
    Pollowick Screwfix Select
    Are these the 250/500 wide PVC panels that are stuck to the wall?
    IF so, unlikely that a quality repair could be achieved and it may need replacement panelling. And it will probably need ALL of them doing to ensure matching of the panels between batches.
  8. Rebecca Price
    Yes they are, Rang him and he said he was coming back with some colored silicone I asked him which one and he says its pro 3 silicone adesive filla
  9. Pollowick
    He can try but ultimately it has to be your acceptance of it - will it match for colour and pattern? will it remain waterproof for 25 years?
    Do you know the brand of panels? If so, call the manufacturer and get their advice.
  10. Rebecca Price
    Thank you will do
  11. sospan
    sospan Screwfix Select
    That's always going to show and the only way is to remove it and replace and because the other panels seals will be disturbed and may need to be replaced
    Heat likes this.
  12. Heat
    Heat Screwfix Select
    As many of the above suggest, the panel would need replaced.
    It might be possible to replace it and 2 or 3 beside it and get them all pushed into their joints properly
  13. DIYDave.
    As I guessed would be the ‘solution’
    But ...... this is a brand new instal, panel has been damaged, any repair is gonna be a bodge and it’s not gonna be perfect
    Cleaning the panels may partially dislodge the silicon over the years and I bet he’s just gonna pump a load in the hole and smear the excess over the panel face
    Surely he’s got insurance for such issues as it’s his responsibility to replace
    Has he actually asked / discussed the silicone approach with you ?
    I guess this is an admittance that he has caused the damage so that’s a positive at least
    Seems like a reasonable chap ?
    Good working relationship during job?
    Happy with the work carried out ?
    Be sympathetic to him but be firm and say your not prepared to accept a repair - sorry
    Was the plumber organised by the builder or yourself ?
    And the clincher ........ have you fully paid for work ?
    Sorry for so many questions and good luck :)
    PS. Also I would imagine that any ‘repair’ would null and void the guarantee offered by panel manufacturers
    This I’m sure you would be able to get in writing from manufacturer / supplier if any further leverage is needed in solving this issue
    Heat likes this.
  14. Rebecca Price
  15. Rebecca Price
    Plumber supplied by builder. They would have to take out the shower cubical and tray. It was put onto a stud wall. It was a job that was supposed to take 2 weeks and has taken nearly 5 as there has been days he has not turned up. Builder is reasonable bloke been held up with all the other trades. He didnt tell me about the damage I had to ring him and this was his solution
  16. gas monkey
    gas monkey Well-Known Member
    new panel
    rest is not your concern
    Heat likes this.
  17. The Teach
    The Teach Screwfix Select
    Might be able to get a smart repair,have used a vehicle smart repair guy to do repairs to chipped floor tiles,chipped basins,gouged pvc doors and a few more ;)
