PVC to Clay Underground Drainage
Discussion in 'Builders' Talk' started by Julian1, Aug 28, 2008.
  1. Julian1
    Julian1 New Member
    Hi
    Can anyone please advise how I can connect a PVC pipe to the socket of a clay pipe. I'm hoping to be able to save the socket when removing the cement from around the socket. Assuming I can save the socket can I cement the PVC pipe in?
    If the socket breaks an I have to cut it off what the best way to connect PCV to the clay pipe.
    Please advise on both scenarios......Thank you.
  2. The South
    The South Member
    buy a flexible connector to connect the plastic to the clay pipe
    one of these is what you want: www.screwfix.com/prods/19914/Plumbing/Underground-Drainage/Flexible-Adaptor
  3. trench
    trench New Member
    Thats what you need but you'll have to cut the socket off the clay pipe with a stihl saw so you can join up the 2 sections of pipe
  4. Julian1
    Julian1 New Member
    Gents, any reason why I cannot cement in a PVC pipe into the clay socket if I'm able to save it, as it is now?
    Thanks
  5. The South
    The South Member
    I suppose you could - but I certainly wouldn't!
  6. trench
    trench New Member
    That would be a bit rough. I would cut it and use the proper adaptor.
  7. sinewave
    sinewave Screwfix Select
    Alternatively you could cement in a small length of clay pipe with no collar on it (if you have any laying about) and then plastic adapter to that.
  8. doing a bit
    doing a bit New Member
    you can get a universal adaptor for plastic to clay, if the clay is existing and the plastic is new and upstream, mc alpine make one a DC1-BL, have a look at the website www.mcalpineplumbing.com , really easy fo fit just grease the fins, it will fit into the pipe or will go into the socket. i wouldnt cement a plastic pipe into the socket as it wont stick to the plastic and isnt flexible to allow for any movement
  9. Julian1
    Julian1 New Member
    Hi, is the McAlpine DC1 - BL suitable for underground connection?
  10. doing a bit
    yes used them before, think b&q sell one as well if its local
  11. Hugh Jaleak
    Hugh Jaleak Member
    Osma part no.4D 107 110mm uPVC to clayware socket. Ive used one of these before, cemented it in.
  12. Moto Slug
    Moto Slug New Member
    Julian,its VERY unlikely you will save the collar as its nigh on impossible to clean out the old cement without them breaking.
  13. Julian1
    Julian1 New Member
    Looks like the OSMA adapter will do the job if I can save the collar but the fitting instructions talk of 'Caulking with tarred yarn/gaskin' which I have not done before and then finishing off with sand/cement. Anyone ever done this process?
    Thanks
  14. doing a bit
    its a bit like hessian , you put that in covered in tar and then fill with sand and cement, the tar makes the seal. stick with the mc alpine or similar , no tar reqd !
  15. john the builder
    john the builder New Member
    anyone have any idea where to get this Gaskin / cauking / tarred stuff...i have the same job on..ive got the coupling 4D/107 but i need the tarry stuff.....
