PVC Window Key Snapped in Window lock
Discussion in 'Other Trades Talk' started by Luigi P, Feb 20, 2005.
  1. panlid
    panlid New Member
    i can cut a piece of 4x2 in half with just the power of concentration!!!
  2. panlid
    panlid New Member
    bstyle what make of vacuum was it and do the local locksmiths use this technic?
  3. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    I can break wind with no effort whatsoever.
    Handyandy - really
  4. bathstyle
    bathstyle Active Member
    I know what you mean, sometimes I just turn up to call outs just to pick up the cheque
  5. bathstyle
    You being serious Sid?
  6. panlid
    panlid New Member
    yes i really can cut wood like that.
  7. panlid
    panlid New Member
    bstyle i forgot all about my auction for the circular saw and it went but there is one on now for £110 buy it now. since the other went for £100 i cant be bothered messing and i am going to get it. just to stop my spark from moaning. lovely bit of kit and i also believe the can do the times crossword in ten minutes;)
  8. bathstyle
    Yeah, thats the next tool for me, I bought the fein Multi last week so I'll have to wait for a lttle bit until I get one.
  9. bathstyle
    Has anyone used the 24 mitre saw?? That seems quite reasonable at £229
  10. panlid
    panlid New Member
    i saw that and am seriously tempted. i read a review in my woodworkers mag and it said it was a good bit of kit though obviously you cant just thrust blade down you have to let blade do the work. i am looking for a small chopsaw as i am fed up with dragging my big dewalt in just to do archs and beads etc. most of my work is second fix and i only need big saw every now and then so i could leave that in the garage mostly. but i dont know how heavy or how big the bosch is and wanted to try it out first in a shop.
    ohh the temtation.....
  11. dewaltdisney
    dewaltdisney New Member
    Okay Sid,
    I will swap my chop saw for your Dewalt if you like. Seems like a good deal to me as it is very light and cuts internal skirtings accurately
    DWD
  12. shaunie
    shaunie New Member
    hi guys, juat jumped in on this thread, i can cut through a mains water pipe with a digger bucket as easy as anything :)
  13. Stoday
    Stoday New Member
    You should be using that digger as a divining rod shaunie.
    What the f*k's a digger got to do with a snapped key?
  14. Mr. Handyandy
    Okay Sid,
    DWD
    Christ, you don't mitre internal skirting, do you DWD ?
    Haven't you heard ? That's sacrilege!!!!
    Or is your chop saw intelligent enough to cut scribes ?
    :) Handyandy - really
  15. ChristineWi
    ChristineWi New Member
    Thanks for the advice everyone - particularly the vacuum advice. Managed to retrieve broken end of key from bathroom window. Used the "deflate" setting of a mattress pump. Bought a replacement key from eBay and everything is back in working order. Am very relieved!
  16. koolpc
    koolpc Screwfix Select
    You could have used dynamite! Awesome on window issues!
    ChristineWi likes this.
