Pvc window stuck shut
Discussion in 'Builders' Talk' started by Dave Beard, Apr 12, 2020.
  1. Dave Beard
    Dave Beard New Member
    Hi all,
    We have a window in our bedroom which is stuck shut, the handle turns but the window won't open.
    When the handle is in the unlocked position, the left side has some movement like it would open but right side doesn't.
    I've taken the handle off and spindle was attached,.
    I'm not a window fitter but I'm assuming this "pin" is jammed in on the right side. ( see picture ) 20200412_164254.jpg
    Can anyone adivse if this sounds right and if so, how to release it? Can access from the outside if needed.
    Picture is of an identical window in bedroom next to it
    Cheers
