Q for Mudster
Discussion in 'Other Trades Talk' started by Boxer Red, Oct 28, 2005.
  1. mudster, would you use 4mm ply then?
    You know, where people get the idea this is sound is beyond me, even Amtico needs 6mm ply and that's a vinyl...
    Go figure....
  2. dj.
    dj. New Member
    pva mixed with cement and it will give you a nice non slip surface too.
    really
    tkf, using double sided sticky tape is a bad idea, i use wriggleys gum glue. ;)
  3. panlid
    panlid New Member
    i know registered amtico fitters and they only use 4mm ply.
  4. bathstyle
    bathstyle Active Member
    slip surface too.
    really
    Incorrect, this method only works on Manhole covers ;)
  5. How about cling film?
  6. Stevemastic
    Stevemastic Member
    I was going in with slabs set on a bed of dry mix, but you guys have got it covered
  7. bathstyle
    You could probably get away with 4mm ply but I prefer overboarding with 6mm ply, as it works better when countersinking screws, I find the 4mm a bit too thin for me. I mostly use Karndean though which is thinner than Amtico
  8. dj.
    dj. New Member
    DUST, a nice layer of dust should strengthen it up nicely.
  9. bathstyle
    Sorry too thick
    The step would be enormous
  10. Stevemastic
    Stevemastic Member
    wack em down with a spade!!!!
  11. Boxer Red
    Boxer Red New Member
    Excuse my ignorance, but whats WBP? How thick is aquapanel? Bear in mind I can't have a big step at the door.
    Some post have certainly had me in fits of laughter!!
    BR
  12. panlid
    panlid New Member
    <u>DUST, a nice layer of dust should strengthen it up nicely.</u>
    LMAO:D
  13. Final solution 2 coats of PVA
  14. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    At no point do you need to use marine ply, WBP is fine.<<
    Hahahahahahahahahahhahahahahahahahaha a hahaahahaha
    hahahahahaha :):D
    Stick the vinyl to the bottom of your shoes - wall to wall vinyl in every room of the house.
    Mr. Handyandy - really
  15. Aquapanel is 12mm thick.
    Does the room outside have carpet?
    If it does this is usually 18mm for a good carpet and underlay, often you won't notice any step.
  16. panlid
    panlid New Member
    errrrr.
  17. Boxer Red, sorry your post got hijacked, listen to Mudster, he's spot on
  18. bathstyle
    Boxer, why don't you use a hard wood threshold strip. I normally buy the wood and plane it to suite the different levels
  19. Excuse my ignorance, but whats WBP? How thick is
    the door.
    laughter!!
    BR
    Oh and WBP is a specification of ply, that is suitable for your requirements, I can't remember what the letter stand for but you don't need to know..:)
  20. WBP - weather and boil proof.
    WBP ply must be able to withstand 72 in boiling water (god knows why) without delaminating.
