Question on mineral wool
Discussion in 'Screwfix' started by Enda Kelly, Nov 22, 2021.
  1. Enda Kelly
    Enda Kelly New Member
    Hello,
    I need mineral wool about 20mm thick to fill a gap in a wall. The thinnest I can find in 25mm.
    Is there an alternative I can use, or will the 25mm squash in (it is mainly just to prevent an echo passing through the space).
    Thanks.
  2. Jord86
    Jord86 Screwfix Select
    Cram it in.
  3. Enda Kelly
    Ha ha, thank Jord......I will give it a try
  4. Jimbo
    Jimbo Screwfix Select
    A bit of density will improve the sound absorbing capabilities. If it's standard loft stuff could go quite a bit thicker nominal thickness.
