Question regarding worktop joints....
Discussion in 'Carpenters' Talk' started by pommychick, Aug 31, 2016.
  1. Phil the Paver
    Wait until he offers you either one of these as a repair option.
    :p:p:p:p:p:p:p
    Joe95, FatherStack, TheMorg and 2 others like this.
  2. Rulland
    Rulland Screwfix Select
    Repair?, that's how I normally joint them!:cool:
  3. chippie244
    chippie244 Super Member
    Council house joint :):)
    Joe95 and Doall like this.
  4. dwlondon
    dwlondon Active Member
  5. koolpc
    koolpc Screwfix Select
    Nothing wrong with a council house! Don't be a snob!
  6. Pommy, what's happening?
    And could you answer the Qs in post #40, please - what type of tops do you have?
  7. dwlondon
  8. chippie244
    I didn't say there was but you only tend to see them in council owned houses.
  9. Astramax
    Astramax Super Member
    What a load of Gollocks! see em everywhere.
  10. metrokitchens
    metrokitchens Screwfix Select
    look better than a blown chipped mitre :D
  11. metrokitchens
    They are used in Buckingham Palace. ;)
  12. chippie244
    I don't think I have ever seen one in a privately owned house, certainly not where they could afford to hire me.
    Isn't Buckingham Palace a large council house?
    metrokitchens likes this.
  13. Astramax
    Chips me ol darlin....get out more
  14. chippie244
    To be honest the sort of people I do private work for wouldn't accept a worktop joiner.
  15. Astramax
    That must make you an accepted 'Worktop Joiner':p
  16. Coral Benham
    Coral Benham New Member
    It might not be the answer to your problem but we have found a repair trim for the Mason Mitre joint. We got water damage in ours and had been told that we would have to replace our whole work top, because of the sink and hob this meant replacing 3 work tops.
    Because we found this trim all we had to do was rub down the damaged area and run silicon down the joint and press the trim into place. It was so much simpler and cheaper than replacing all the work tops. I have only found one website that supplies this http://www.masonsmitretrim.co.uk/ hope this helps other people with the same problem we had.
  17. chippie244
    This stinks of Spam and you end up with a council house joint.
    Joe95 likes this.
  18. sospan
    sospan Screwfix Select
    And doesn't give much of an improvement from your £19,99 compared to the usual couple of £ :rolleyes:
  19. masterdiy
    masterdiy Screwfix Select
    Isn't it a bit odd, we haven't heard from pommychick since Sept 3rd.
    You would have thought we would have had a comment or two from them.
    After all they did ask for help from the experts.
