rad weld [car]
Discussion in 'Car and Van Talk' started by 1rocky1, Apr 5, 2016.
  1. 1rocky1
    1rocky1 Member
    hi all , hope alls good ! anyone had any luck with coolant system sealer ? good or bad ? regards richard.
  2. Phil the Paver
    Yes and no, depends on how bad the leak is, there are many types of rad weld out there.
    So manufacturers don't recommend the use of because they can block the heater matrix.
    CGN likes this.
  3. 1rocky1
    1rocky1 Member
    yer have read this to , just cannot find leak at mo ! thanks.
  4. Phil the Paver
    So, should have said some. :)
    If you can't see the leak, it could be a head gasket failure, this can sometimes be checked by just smelling the water in the header tank, or look for bubbling in the header tank with the engine running, don't mistake water flow for bubbling, you will see air bubbles, also look at the oil filler cap, has it got white scrum around it a sign of water in the oil.
    If you suspect a head gasket or even just a leak, use K Seal, probably the best out there, just make sure your manufacture doesn't say don't use any type of rad weld.
  5. 1rocky1
    1rocky1 Member
    many thanks phil , will have a look for bubbles tomorrow , theres no white stuff on filler cap , it seems intermitant sometimes it loses water sometimes it dont ! seems really strange its a volvo s60 2.0t 2002 done 99000 regards richard.
  6. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Sounds like a high pressure leak then. Look for signs of water stain at pipe connections.
    Mr. HandyAndy - Really
  7. 1rocky1
    1rocky1 Member
    thanks andy will do , stressing me out !lol.
