Hi all, I have a re-wire to do where the people are on a bit of a tight budget so i'm thinking of using 2.5mm radials in the lounge, dining room and bedrooms. One radial upstairs with 5 sockets and one downstairs with 6 sockets. My usual method would be rings but in an effort to keep costs down I thought i'd give radials a go on this one. I'll put a ring in for the kitchen though, I know there's no regs issue but any thoughts on this chaps? It's only two bedrooms by the way, quoted 3k but need to get down to 2.5k
Although don't like Radial Finals generally myself..I think what you propose is ideal Sen within your stipulated parameters on the install.
sene- If your`e doing a rewire with a 17th consumer you need to split the upstairs sockets from the downstairs sockets and the upstairs lights from the downstairs lights would suggest up sockets with down lights on one RCD and down sockets and up lights on the other RCD Radials would be the way to go and ring for the kitchen perhaps
hi sen..no probs with radials!!re the cost issue,your not saving that much by not returning back to cu...possibly save a bit off time on testing..and poss 50 mtrs t/e..but at 2.5k..theres still a good chunk off profit!! 5 days lab, £600 materials..u cld even use mk and make good for that price!!..... and still have a good week regards rob.
Nice one Sen. Was I right about the 7 days max?..maybe you could do it in 4 or 5 days. I know Wally 2 is in his sixties, and he is still doing loads of work.
Mine's on 7th JP. I think it might be 7 days although I don't have to muck about with carpets etc too much, she said just cut them up as necessary as they are going to be replaced, there's not too much furniture there either as they haven't lived there very long, not much making good to be done either, just a bit of bonding over the chases and they'll finish off when they decorate. I have a mate that can come in for a few days to help at the beginning, he's not a sparks but is pretty handy for lifting boards, cutting chases and running cables etc so I might do it in 5 days. Dave.
Brilliant Sen. It is a luxury when someone else does the floor boards and lifting stuff about etc..you can spend more time getting other stuff in ready to cable etc. Anyway must go, have a good evening Sen.
