Radiator btus
Discussion in 'Builders' Talk' started by Mr Melvin Nightingale, Jan 14, 2020.
  1. I have a vertical double radiator rated at 11504 btus, at what temperature do I need to run my boiler at to attain this?
  2. Hans_25
    Hans_25 Well-Known Member
    That rating is likely based on a temperature differential of 50 degrees or so, so say 65-75 degrees flow and 25 degrees return. The higher the temperature you run your boiler, the more heat will be given out, but the less efficient it becomes (assuming its a condensing boiler).
    The Teach likes this.
  3. Hi, yes I understand that the higher the boiler temperature the hotter the radiator, I just wanted to know at what boiler setting do they use to rate a radiator?
  4. The Teach
    The Teach Well-Known Member
    have a uk search for DeltaT
    its all your installer needs to know ;)
  5. Hans_25
    The installer would be Mr T then :D
  6. The Teach
