Radiator on plasterboard wall before plastered
Discussion in 'Plumbers' Talk' started by albartuk, Sep 26, 2021.
  1. albartuk
    albartuk New Member
    Hi why would you hang a radiator on a plasterboard wall and test the system, then drain it down take it off and plaster the wall and put it back fill it then drain again and take off to paint, other than to waste time and customer money!!!
  2. terrymac
    terrymac Screwfix Select
    Help to dry the plaster out quicker ?
  3. dcox
    dcox Screwfix Select
    Makes sense to test before skimming. Not sure why you’d do it again before painting though.
  4. pppmacca43
    pppmacca43 Super Member
    Normally you would hang it with new valves, fill up to the valves but leave them off and leave the nuts loose so u can take the radiator off for decorating. Then after room is painted, put radiator back on and tighten nuts and fill up rad
  5. Wayners
    Wayners Screwfix Select
    Sounds like a normal no project management I see daily.
