Radiator on studs on top of bricks
Discussion in 'Plumbers' Talk' started by phloaw, Jul 24, 2021.
  1. phloaw
    phloaw Member
    I need to hang a radiator (160cm wide, 50cm high, total weight around 35kg) via two brackets to a plasterboard wall.
    The wall is external, so that it has studs (about 12mm deep and 50mm wide) behind the plasterboard and then bricks behind the studs.
    I am lucky enough to have studs in correspondence of my brackets.
    However, I was wondering whether the 12mm depth of the studs would be enough for the screws to bite, or if I should reach to the bricks behind the studs and fix the brackets to them.
    If I can use the studs, how do I make sure that the screws go through the whole 12mm, given that this will be prevented by them hitting the bricks?
    Thanks.
  2. pppmacca43
    pppmacca43 Super Member
    Drill and plugs into the brick work, 12mm of wood is not enough to hang a radiator on.
    phloaw likes this.
  3. AnotherTopJob
    AnotherTopJob Screwfix Select
    Probably best to use a frame fixing through the stud and into the brickwork.
    phloaw likes this.
