Radiator Pipes behind Plasterboard?
Discussion in 'Plumbers' Talk' started by Mullaghconnolly, Jul 28, 2021.
  1. Mullaghconnolly
    Mullaghconnolly New Member
    Hi, we currently have wall mounted radiator pipes which were “hidden” behind trunking - see pics. The plaster has blown so I’m planning on replacing it with plasterboard on battens. I’m using battens rather than dot and dab as I want some acoustic insulation in there too. My question is whether it’s ok to have the pipes behind the plasterboard and if so, is there a way of doing it without too much plumbing work? Might the pipes have to be temporarily disconnected at the top?
  2. jonathanc
    jonathanc Screwfix Select
    It’s fine. I would change to 10mm speed fit at the ceiling level and drop down with that
  3. Jimbo
    Jimbo Screwfix Select
    will the door be able to open?
