I have a hint of a weep from the 'stub' at the bottom of the new radiator (male connector to connect the valve). Used plenty of PTFE tape - twice. Should I use jointing compound instead? Thanks (again) WM
Right, right, right what have you done Mally to upset the radiator??!!! Try some more PTFE & nip it right up!!
Maybe just a bit gentle with it, Dick - I'll go large with the PTFE and give it some wellie! Cheers WM
