raising a chimney lintel and opening up for cooker
Discussion in 'Builders' Talk' started by jlintel, May 27, 2020.
  1. jlintel
    jlintel New Member
    Hello I'm opening up a chimney breast
    1400mm wide aiming for a 1100cm opening.
    questions
    how thick should the brick columns/cheeks be on either side to support the lintel?
    the chimney flue/bricks inside go across the chimney will these bricks need supporting once removed? fireplace lintel raise.png
    many thanks
  2. jlintel
    jlintel New Member
