Guys I have a kitchen door which rattles at times when it's very windy outside. The flooring is tiles in the kitchen which I'm not makes a difference. Obviously there is a draught coming in but not manage to isolate it yet. What my issues is the door rattles slightly. When the door is closed and I push against it, it's rattling against the frame. How can I fix it properly? Or should I just put some draught excluder inside the frame.
Some keeps have a metal tab that you can bend to put more pressure onto latch - saves moving keep Either way, an easy job
Unscrew the keep, bend the metal tab or chisel new opening, screw the keep back on. 1 screwdriver, 1 pair of pliers or hammer and chisel.
