Evening guys. Right first of all the supply type is 220volts, 60Hz TN-C-S (country abroad) Right I have found rcbo's at 50 to 60 hz but all are rated at 230v. The inevitable question - do you reckon its ok to run above on 220v instead of 230v? (in reality our pd is 240v but that is neither here or there) Thanks guys.
I've not relly got my thinking cap ( very long week) on mate but I can tell you RCD's are current based so I can't see why the voltage would make any difference.
Thanks Mr C - it is only 10 volts off the 230 stamped on the rcbo body. Do you reckon I should also ask the manufacturer if it is ok?
My main problem also is that of course when I have finished the electrics it will be to English standards - it all has to be tested and certificated, maybe they might refuse certificate because of alternative wiring etc?
Your right Sen - I've got a habit of over complicating things and yes your way is best..as long as everything tests ok thats the main thing.
The DP main switch would be ok at 60Hz? The earth cable coming from rod/rebar to met is single strand, and they use aluminium cables etc flipping heck
Have a look at the MK Technical Spec. http://www.mkelectric.com/en-gb/Products/CP/sentry/RCBOsinglepoletypeb/typeaconly/Pages/7932s.aspx download it from the link. If you scroll down it just says 230V for RCBOs however for their RCD, they say 100-250v You will need to speak with the manufacturer to confirm it all.
Thanks Mr P - if I cant go ahead with rcbo's then I will think of a dual rcd, it wouldn't give me high integrity though, but cant have everything. I will have to confirm everything with the manufacturers I agree 100% At the end of the day if it is a no go then I will have to do it all there way - but would not be happy doing that tbqh..I am not saying there way is bad, but our systems really are tried and tested.
