My shower has no RCD protection..:O (It's non electric) But it's run off a Combi Boiler.. That's connected to the Ring main.. Which is RCD protected...:O :^O
I would ask the question, if a manufacturer is requiring an RCD to be fitted, has he doubt about the safe operation of his product? No. He doubts the earth continuity can be maintained. How can a properly installed shower create a hazard? Only if the bonding/earthing becomes o/c. So the RCD is only protecting against this fault. I'd be happy to shower without an RCD if the plumbing were soldered copper throughout but less so with compression fittings. With plastic, I'd want an RCD because I don't have a second earth route as a back-up.
I would ask the question, if a manufacturer is requiring an RCD to be fitted, has he doubt about the safe operation of his product? No. He doubts the earth continuity can be maintained. How can a properly installed shower create a hazard? Only if the bonding/earthing becomes o/c. So the RCD is only protecting against this fault. I'd be happy to shower without an RCD if the plumbing were soldered copper throughout but less so with compression fittings. With plastic, I'd want an RCD because I don't have a second earth route as a back-up. Have you seen the 'Curvey Blonde In The Shower' thread?
I'd be happy to shower without an RCD if the plumbing were soldered copper throughout but less so with compression fittings. With plastic, I'd want an RCD because I don't have a second earth route as a back-up. Titter titter.....
Not being funny like, but I've never ever seen a shower with plastic water pipes.. Anybody..? A good/bad thing..? :O
Extension you can plumb showers completely in plastic pipe and a heck of a lot of other stuff to....however you will never ever beat good old copper tubing (thats my view anyway).
Extension you can plumb showers completely in plastic pipe and a heck of a lot of other stuff to....however you will never ever beat good old copper tubing (thats my view anyway). Mmm...Have to agree..perhaps the 'Curvey Blonde' had plastic fittings.. :O :^O
Have you seen the 'Curvey Blonde In The Shower' thread? I have now. It does not cover my point, which is, how can a faulty shower electrocute the user if it's earthed properly?
http://news.bbc.co.uk/1/hi/wales/southeast/4130223.stm http://news.bbc.co.uk/1/hi/wales/4679129.stm http://www.irwinmitchell.com/PressOffice/PressReleases/hotel-injury-electrocution.htm http://www.mikeholt.com/documents/powerquality/ShockStray.pdf Hope this helps...
Have you seen the 'Curvey Blonde In The Shower' thread? I have now. It does not cover my point, which is, how can a faulty shower electrocute the user if it's earthed properly? There may be insufficient fault current to trip the mcb (which may be rated at 40A, for example) and if no RCD is fitted, current will pass indefinatley... If a fault current of say 10A is flowing, we only need 50mA to kill the person in the shower, thats just 0.5% of the total current.. Assuming the other 99.5% is flowing down throught the pipe or the cpc. Who knows what possible fault senarios can occur..
http://news.bbc.co.uk/1/hi/wales/southeast/4130223.st m http://news.bbc.co.uk/1/hi/wales/4679129.stm http://www.irwinmitchell.com/PressOffice/PressReleases /hotel-injury-electrocution.htm http://www.mikeholt.com/documents/powerquality/ShockS tray.pdf None of these examples are directly caused by not having an rcd fitted to a correctly installed shower unit. The last link is related to wiring in the USA ,is that relevant to the British system? Hope this helps...
one guy was found with the shower unit on top of him ?? did it fall off the wall and kill him ? or did he pull it off
The inquest heard Mr Eldon was using an extension lead from his mother's house next door for his electricity supply. having your shower running off an extenstion lead from next door is asking for trouble
None of these examples are directly caused by not having an rcd fitted to a correctly installed shower unit. The last link is related to wiring in the USA ,is that relevant to the British system? Quite so, LD. The USA link is interesting because it describes the sort of PME system that was allowed by the thirteenth edition (I think) in the 1960's. Of course that's now changed and the problems identified could not arise in the UK if the installation complies with current regulations.
