Hi All, I pulled out a radiator for decoration and had to remove screws and plugs as well. I found the older screws to be of 60mm length, the wall is a solid brick wall. Can I reuse the screws? Or should I buy new ones? I tried searching but I am very confused on what screws and plugs to use with the radiator. I am attaching a picture of the screw and radiator. Thanks in advance for your help
Thanks for your reply. Should I be filling the holes? Since these are 60mm and I will be using 50mm ones ?
Will these plugs work ? https://www.screwfix.com/p/rawlplug-plastic-plugs-6mm-100-pack/35984 I am still trying to find the correct screws
And these are the four options I can see for the correct length and diameter : https://www.screwfix.com/c/screws-n...0066&productlength=50_mm&screwdiametermm=6_mm
