Recess led light spacing.
Discussion in 'Electricians' Talk' started by TheGrovesy, May 24, 2014.
  1. TheGrovesy
    TheGrovesy Member
    Hi all.
    I have just had my bathroom rewired including the fitting of several recessed LED lights. I now want to put some boards in my loft where the lights come through.
    My questing is is it ok to board straight over these? The joists are 4", with the back of the lights protruding around 2", so boarding over them would still leave a clear 2" space.
    Thanks.
  2. Almost certainly ok since LED lamps tend to become 'warm' at most, and nothing like the temps of halogens.
    No insulation packed over the lamps?
  3. TheGrovesy
    TheGrovesy Member
    That's correct, no insulation over them and an insulation clear space around them.
  4. seneca
    seneca Screwfix Select
    No problem at all then!
  5. Biochef
    Biochef Member
    If there's a junction box up there form a hatch to give access I just love ripping up floored lofts looking for them :rolleyes:
  6. unphased
    unphased Screwfix Select
    Yep. The more remote and difficult to get to the more I love 'em.
